Wiring issue
Hi, I am new to this site but I just recently purchased a used set of hornblasters shocker horns and am having a little help setting my system up. My setup is a set of shocker horns, a 5 gallon Hoosier tank, a 150 psi pressure regulator, and a 480c Viair compressor.
I have everything mounted to my truck and am having trouble wiring it to work. My goal was to have the entire system on a switch so that I can turn the compressor off when I want to. The horns will be attached to a separate momentary switch that will only work when the system switch is activated.
I will try my best to describe how I have everything attached. To start I have the system switch attached to the fuse box, grounded and ran to the Bosch relay. One prong is attached to the ground, one attached to the switch in my cab, another attached to the battery with an inline fuse, and the final one going to the pressure switch with the wire labeled “Ignition fuse”. I also attached the wire that says “compressor” directly to the compressor. The compressor and pressure switch are both grounded to the same place. Finally, the wire label “12V power source” is hooked directly to the battery with the another inline fuse.
Sorry for the long post but it was hard to explain it all. Any help is appreciated and if there are any more questions about my setup just ask. Thanks in advance!
Hi there and welcome to the forum. Please have a read of this thread because we just had someone with a similar kit that went through the learning curve on how to hook everything up:
https://www.trainhornforums.com/showthread.php?t=6574
Let us know if you still have questions or specific issues you need help with.
Thank you very much for your reply! I think i have it figured out and will fix it tomorrow. Thanks again
Welcome to the forum and good luck!
