Wiring question
Im down the the last part of my install all that is left is wiring my switchs in the cab. I found a diagram written by someone on here a while ago for exactly what i want, a switch to turn the compresser ofr and a push button for the horns.for the button it says i need a fuse but do i need one? If i do need one what amps should i use and where could i buy it. …on a side note im pretty proud of myself doing this install being that im 16, im good at almost everthing expect wiring stuff.
10 amp fuse, available at pretty much any Wal-Mart, automotive store, gas station, hardware store, etc., … alot of places carry them.
Kris
you want to use the 10amp fuse from the power to the switch… then out to the compressor… also to save your self burnt wires too… when you wire up your train horns run a 10-15 amp fuse from the battery to the horns and use ground when you hook up the button for the BLAST… GL
