Hey all. Been stressing a ton over this. 2017 GMC Sierra 2500HD. Shocker XL horns with Viair 20005 compressor setup. Colby from Hornblasters has been a huge help so far, but I wanted to post here too.
I want to have my toggle off and honk with the factory horns. Turn the toggle on and honk with my train horns. All on the steering wheel. No splicing into horn wires since I can tap into the horn fuse according to an article on here.
I’m using 2 6-prong latching/LED switches. Wiring diagram will be attached.
Current switch wiring:
- to an accessory fuse
1 and 2 not used.
3 and - go to my valve. Diode in between to dim LED on OFF position.
4 goes to ground.
Current valve wiring:
1 wire to horn tap for power when hitting horn.
Other wire to my toggle. Which is connected to 3 and -
Current Relay wiring: (compressor circuit)
- 85 to ground
- 87 to battery with inline
- 30 to compressor positive with 10g wire
- 86 to pressure switch
Potential compressor toggle wiring:
- Toggle switch Pin 3 to accessory fuse
- Toggle switch Pin - to ground on frame
- Toggle switch Pin 4 & + to relay pin 86.
Please help me lol! Not sure if something is mixed up, wrong, or what! I do great with basic diagrams and dumbing it down.
