Has anyone ever used the Wolo 840 set up? New to this stuff, a friend gave me a set of horns off his rollback and i need an air setup. Found this air tank,comp,lines,pressure switch and everything for $145.00. The horns have a 1/2 inch line on them now and this set up is 1/4 in. Just not sure if it will put out enough air. Fired off the horns at my shop with 120psi and they are real loud. That was through a blow gun, so let me know what you guys think.
The compressor and tank I saw on their website are small. It will probably take awhile for the compressor to fill the tank and you might get one good blast out of the tank. It should work for you but don’t be surprised if you want to upgrade in the near future. If the horn port is 1/4" then using 1/2" line won’t help.
