the compressor i have, i got from work…anyway, not sure on the brand but it works but i wish itd fill a little faster. i read somewhere that itll only blow as much air as the exhaust will fit.
right now the exhaust on it is only 1/4", if i drill and tap it out to fit my 5/16 fitting, would this help?
Increasing the size of your exhaust may improve the output but probably not by much.
yea, id like to buy a set and run duals…but i dont have the cash right now…so im trying to work with what i got
If that’s your truck, do you air down the tires? If so look at our website - www.oasismfg.com - check out the automatic tire deflators.
yea ive seen those…they would be nice but i got plenty of other things to spend that much money on, they tend to be a little spendy…like my front gears, i cant even use 4wd right now cause my gears are different in my axles…
$60 + shipping is spendy? If you do air down, think of the time you’ll save.
