Gentlemen…
Thank you guys in advance for any advice you may offer.
What I’m working on is a replacement of my current setup. I have an “older” Hornblasters Shocker type kit on my sub compact sedan:
^Since this picture I’ve replaced the 375c compressor with a 400c piece.
^This is an old picture of the original setup. I’ve since moved the horns and removed some unnecessary panels from the car to allow a more direct air line fitment.
What my goal now is to replace this four horn setup with a Nathan K3LA. What I’m looking at is purchasing the raw K3LA horn set. Realtrainhorns sells a relocation kit for the K3, I was going to pick that up. I was going to then purchase a bigger electric relay operated valve…then a tank.
Now, not knowing too much about the K3LA, What should I be purchasing in the way of a tank & electric valve?
My thought was to purchase a 5 gallon tank like this:
http://realtrainhorns.net/shop/index.php?act=viewProd&productId=77
^This should fit in between my rear wheel wells. I can probably use the 150 check valve that I have wired in to the compressor by using adaptor fittings into the 1/2" ports on the tank. I’m not concerned about fill time at this point.
Running the lines up to the valve is simple. But then…what valve? I was thinking that the tank has the 1/2" ports so…1/2" line out to the valve?
http://realtrainhorns.net/shop/index.php?act=viewProd&productId=124
Then from the valve to the mounting kit. The issue I’m having is that I’m not receiving any communication from the website to answer any questions about the relocation kit…which isn’t a good sign.
http://realtrainhorns.net/shop/index.php?act=viewProd&productId=138
My goal is to replace the 4 horns with the REAL horns and make this the loudest Toyota Yaris horn that anyone will ever hear. I currently have the kit wired onto the stock horn. I use the current horn only when absolutely needed…in an emergency or a demo. It truly is loud…BUT…I know I can get louder…
Thoughts? Advice?
