This is going to take forever, but I might as well share as I go.
So far a big thanks to:
Garrett @ Hornblasters
Tommy Aker
Paul @ Air Zenith who is going above and beyond in getting me a custom tank
Basic plan is a custom 10 gallon tank and 2 AZ OB2 compressors in the front of the bed.
All horns up front behind grill/bumper or under the hood.
I started with a K5LA and bought 4 more bells for a total of 1L, 1, 2, 3A, 3, 4A, 4, 5, 5
Solenoid Valve #1 – 1L, 1, 2 - with a ball valve on the 1L
Solenoid Valve #2 – 3A, 4A, 5 - with a ball valve on the 5
Solenoid Valve #3 – 3, 4, 5 - with a ball valve on the 5
200psi in tank regulated to 150psi.
All 5/8” ID hose except to individual bells.
Thanks guys. I’m looking forward to hearing them too! Other than just messing around 1 bell at a time…lol
Thanks Garrett - I actually sold the 8.5 in favor of a loooong skinny 10 gallon. Been working with Paul @ AZ for a tank with compressor brackets to display the dual OB2s. I’ll try to remember a PM to you.
I noticed you guys said that will work good with his 8.5 gallon tank. Is that enough for all those bells ??? Cause I like to lay into mine for a second and 5 gallons is gone like nothing. BY THE WAY I LOVE THE COLOR OF THOSE BELLS !!!
Thanks.
I sold the 8.5 and have 2 temporary 5 gal. Still working on getting a custom 10-12 gallon made.
My stereo install is getting close so I can move on to the horns.
finally, Finally, FINALLY got my new grille. It took 6 months to the day.
Some of the bells are going behind it so I needed it to install everything at once.
Well this will only be installed for a week, but I couldn’t take it any more.
I wanted to blow some people up at a couple parties…
Big thanks to Paul @ Air Zenith for 2 temporary tanks!
Bells 1, 2, 3a, 4a, 5 - standard k5la
The tanks are approx 4 gallons each.
165-200 psi pressure switch is dead on.
Unfortunately no regulator yet.
5/8" I.D. air hose.
#1 question I get: “Aren’t you affraid you’re going to blow out your back window?” LMAO
Anyway, it’s getting yanked out within a day or 2 for a spray-in bedliner. Then I can install my hard tonneau cover.
