This how to is for the newbies that have no idea on which hornblasters train horn kit to get…
Choose which you would rather have; price, volume, size, compressor and PSI. The higher the PSI the louder the horns will be (psi used are 120, 145, 150, 175, and 200). The bigger the air tank the longer the horns will sound (Hornblasters sells a 1.5, 2, 3, or a 5 gallon tank). Also, the higher the price the better the tank, compressor, and psi.
These are just some recommendations… This list is ordered by price.
These kits use the Shocker 4 train horn:
Shocker 127VX Train Horn Kit
The Shocker 4 train horn at $404.99, this kit is the best bang for your buck…
uses 1.5 Gallon tank, Viair 275C Compressor, at 120psi
2.Shocker 228VX Train Horn Kit
The Shocker 4 train horn at $439.99
uses 2.0 Gallon tank, Viair 280C Compressor, at 145psi
3.Shocker Classic 238VX Train Horn Kit
The Shocker Classic train horn at $509.99
uses 2.0 Gallon tank, Viair 380C Compressor, at 200psi
4.Shocker Classic 248VX Train Horn Kit
The Shocker Classic train horn at $544.99
uses 3 Gallon tank, Viair 280C Compressor, at 150psi
5.Conductor’s Special 248 Train Horn Kit
The Shocker XL train horn at $564.99
uses 2.0 Gallon tank, Viair 480C Compressor, at 200psi
The best all around Shocker4 Train horn kit
5.Conductor’s Special 540 Train Horn Kit
The Shocker XL train horn at $594.99
uses 5.0 Gallon tank, Viair 400C Compressor, at 150psi
Real Train Horn Kits:
1.Nathan AirChime P3 Train Horn Kit
Nathan P3 AirChime kit at $1334.99
uses 5.0 Gallon tank, Viair 280C Compressor, at 150psi
2.Nathan AirChime K3LA Train Horn Kit (K3)
Nathan K3LA AirChime kit at $1499.99
The LOUDEST Train Horn Kit you can buy!
3.Nathan AirChime K5LA Train Horn Kit (K5)
Nathan K5LA AirChime kit at $2279.99
