My pop off valve is rated at 175 so for now I will run the 150 psi pressure switch. Then when I get the money I will get a 220 pop off valve, put on the 200 psi pressure switch and a regulator.
Sent from my iPhone4 using Tapatalk.
Also, can I get a link to a good regulator for between the tank and the horns. And should that regulator come before or after the valve?
I am pretty sure it needs to come before the valve…I would think. Lol
I think so too. If not the valve would build back pressure between it and the regulator.
Just got off the phone with HB, got them sending me a 235psi pop off valve and 2 more ptc fittings, also a reducer to hook up my digital gauge.
Well I will be picking up 5/8" ptc and line tomorrow, and ordering a regulator too! Might as well do it big with the K5s!
Haha busy fellow! You won’t be disappointed
what regulator? i am on the hunt for one also. lol
McMaster Carr 225cfm 1/2" regulator with gauge - 4959K303
Bracket for regulator - 4910K98
Thanks bro!
Looks great man! May be a pain at times while you hook it up, but a big sigh of relief and a huge smile once you finish and get to honk it for the first time!!
I called HB because they sent me the 150 psi pressure switch with one built in relay and then the 200 psi switch and 2 relay blocks. I told them I did not understand why I was sent the 150 psi switch and why they sent the 20psi with 2 block relays when they make a 200psi switch with 2 built in relays. I talked with nick, he took care of it and I have a 200psi switch with 2 built in relays on the way!
I also asked about why they dont sell 5/8" ptc and he said I wouldnt need it so I will save that 80 bucks and see how the horns sound with the 1/2" and go from there. thanks for everyones helpe. specially ear2ear!
No problem. It’ll still be ridiculous!
Well my guage came in from hb, the air-zenith, it is a BA looking guage. Can’t wait to get it the truck!
My regulator should be here tomorrow along with my connectors that HB left out and my 200psi pressure switch with 2 built in regulators. So by monday/ tuesday everything should be in!
what are yall doing for security, where someone cant just go under my truck and unbolt my horns?
I bought SS security bolts from my local Fastenal. Can’t remember if I posted pics in my install thread or not. Most people don’t carry a security bit with them
Here you go:
Machine Security Screws
Security Bits
or
Security Drivers
You can order them online or go into the store to order.
I’m sure you can find them other places online too i.e. McMaster-Carr.
Thanks bro!
Sure thing!
J.walton - question for ya -
Did the red wire come with the viair kit?
What gauge is it?
What size fuse is in that big fuseholder?
treylittlefield is asking about wire size in his thread:
http://www.trainhornforums.com/showthread.php?p=52611#post52611
