Ive seen some of these around… i just dont kno where it fits in the whole system…is this a fast compressor. i heard one person was pushing that to a 5 gal tank? and i was like wtf thats slow… i kno its 150 psi comp…
but i think this is on my 2 gal and i can only imagine it on the 5
oh no i have a 380c…my old 2 gal tank has the 280 on it… just looking for the info on it…didnt kno where in the lineup it was…someguy like i said told me he was running a 280 to a 5 gal and it would fill up 0 to 150 in like 5 mintues…which my 380 wont even do?
idk…how bout the 380 c…whats that do for a 5 gal? lance can i use a 150 psi compressor to help fill the 150 and let my 200 psi one take care of the rest? or is that not good?
Using multiple pressure switches is fine if you want to use different rated compressors on the same system. If you have a 150 PSI rated pump, use a 150 PSI switch, and if you want to use a 200 PSI pump to go past the 150 PSI pump’s rating, use a 200 PSI switch for the 200 PSI pump. Keep in mind though, that the 200 PSI pump will pump right alongside the 150 PSI pump until the 150 PSI pump shuts down due to the signal it receives from the pressure switch (also 150 PSI) that is controlling its operation.
Call me crazy but i have a 280C on my 12 gallon tank and it does just fine… put it this way i can blow my k3 as much as i want to and not have to wait on the comperssor.
Yall must be honkin like some motha honkers, it only takes about 10 min. to fill up from 110 to 145psi. and i can get 3 long honks and a bunch of short ones from 145 to 110psi…
