Water Mister
ok i havent on here in a while but i had an idea and this is the best place to ask it
i was with my buddie today and i was talking about putting a purge valve on my tank and he said i should put the valve inside my fender pointing out so i could spray people when i emtyd my tank, then it went from that to a box full of water so i could spray people all the time
now i know its a dick move but just think about how funny it would be to shoot water at someone at the touch of a button
i want the water to shoot out in a spray, not a stream but i cant figure out how to make it spread into mist
i am going to make somekind of a box full of water and conect it to my tank with a valve somewhere inline like this but i dont know how to make it spray like a mist any ideas on what i could change to get the spray im after
thanks
yeah me and matt already had the idea (I think he made one too) about a despenser to spray liquid ass
you need a nozel tip from like a pressure washer hooked to the valve and you need a check valve so the water will not go back into your air tank :wink:
i was thinking about it and the pressure washer tip would be perfect
just set it to fine mist and i could just push the water through it and bam
and the check valve idea is awesome
ill get some pics and vids up when i do it
thanks
o and spraying liquid ass at people is crazy
i think im just going to stick to water lol
Horns are one thing with scaring people, but now your getting in people’s space by spraying things on them. Someone can panic, not know what was sprayed on them, call the cops, and next thing you know the cops or fbi will be showing up. This is 2009, people freak out about things like this.
Now if you do it to people you know, good job. Dont forget a one way valve so water doesnt come in the air tank.
Oh the old school way of doing this is get a old windshield washer bottle with the pump attached to the bottle from the junkyard. Audi’s have high volume pumps. Lot cheaper, will spray as well, and all thats needed is a power wire and a switch. I did this when I was younger. About the same time I figured out how to make flames shoot out my exhaust with a coil, a spark plug, and manual choke on the carburetor. Haha, carburetor.
How many here had cars with one on it.
IMO this is how i would do it. probably a more expencive aproach but i think it would get the best mist. the way you have it you will most likely get more of a stream than a mist. this way you will get a mix of air and water. you can regulate the amount of air. the less air there is going through that line the more water you would be spraying. just for good measure make sure your air is going into the top of the water tank and your are sucking from the bottom, and your water tank can handle the same pressure as your air tank.
get a spray gun (that uses compressed air for painting stuff) fill it with water, figure out a way of keeping the trigger pulled, run a solenoid to the air inlet of the spray gun. and there you have it.
that is a great idea
it had me stumped on how to get that mixture of water and air but it was so obvious lol
your right but im still young and i dont care:D
now im not going to do it at random people walking on the side of the road your right they would freak out and i would just get into trouble but driving by one of my buddies or something just give him a little spray ya know
go look at your horns
nice
I helped one of my firends re rout his windshield wiper sprayer, for the passenger side, all the way through his car, and out through a hole by his licends plate. It actually sprays pretty far. great for tailgaters, or at red lights, or anywhere where someone is behind you.
As for this, lol the only problem I see is the really dirty shit water that comes out of the tank. clean water is fine, but the water that comes out of my tank is a tad dirty. I think my friends would gang up and beat my ass if i did it to them. lol
edit:
It would work on tailgaters :D, imagine it at 200psi?
I second this idea. It would work the best.
lol great idea tqist just drop a turd in your washer tank let it perculate for a few days and spray at tailgaters lmao
oh yeah. would like to do that to those who tailgate me and have their high beams on. happened twice this week. was thinking of having some fog lamps pointing at the rear windshield or a pea shooter-like device hooked to the air tank via my extra valve and ammo is tissue paper soaked in paint stripper. :mad:
yeah i’m putting rear fogs on soon…
yea, f*** water, use paint stripper instead… FTW
i totaly want to do this! im on the hunt for a high pressure water tank…
