Oh wait a minute…
The flow through a 3/8" ID tube will NOT be 291 cfm@ 150psi. The chart you show is for orifices. Tubes are completely different due to choking.
I read a lot of engineering sites, and one I saw had a calculation showing the maximum flow with 100 psi through a 3/16" ID tube at 24" long will be somewhere around 30 cfm!!! The orifice chart shows 50cfm (through an orifice) so the drop through a tube is 40% AND THAT’S JUST A 24" TUBE!
The longer a tube is the more turbulence and friction you will get. The bigger it is, the less you get.
I would feel pretty confident saying bigger is better, but I don’t have the formula for figuring flow in a tube. And then you have to figure it will change with temperature and pressure…
Here’s a short snip of what you would be looking at to begin calculations (from a different site): And remember this is a 24" open ended tube…
[i]
At 2 ft, I’d roll the dice and use the choked-flow equations. They give you a result in lbm/hr that you can covert to CFM:
m(dot) = (pi/4)d^2 * C(m) * P * K(total) * [MW/(T*Z)]^0.5
where:
C(m) = 520 * {k * (2/(k+1))^[(k+1)/(k-1)]}^0.5
k = ratio of specific heats
d = orifice diameter (ft)
P = upstream pressure (psia)
K(total) is a stream of constants that is close to 1.0 for your application
MW = molecular weight
T = temp in Rankine
Z = compressibility (1.0 for air)
For this type of calculation I would assume isothermal flow, although in reality it will be more nearly adiabatic. But isothermal calcs are so much easier and the error, even in an extreme situation like this, is unlikely to be more than 20% (flow too high).
By my calc the flow is definitely choked. The good thing about choked flow is that as the assumed outlet pressure decreases towards the limit, the flowrate varies very little because the outlet density increases so rapidly. So you should get a reasonable number.
I assumed the air reservoir was at 60 F and 114.7 psia. This gives a flowrate of 160 lb/h or 35 scfm. I used a roughness of 5.0E-6 ft (drawn tubing). It is interesting to note that because the friction factor is a function of the roughness divided by the pipe diameter (e/d), and the diameter is small, the flow is very sensitive to the assumed roughness. If you used the usual value for commercial piping (1.6E-4 ft)you would get a flow of only 120 lb/h or 26 scfm.[/i]
